It is currently Sat Jul 26, 2025 1:05 pm
PostPosted: Wed Mar 29, 2006 1:29 am
I just finished my bending form, and I'm looking to buy a blanket, and trying to figure out what's best to get.
Some of you have talked about blanket (or wood?) temperature during bending. How do you measure the temperature? Is there usually a temperature probe inside the blanket? Or, is there a separate temperature sensor that the controller uses? It seems like it would be hard to measure the temperature of the blanket/sides without a sensor right in the blanket. If you stuck some kind of sensor outside the wood/blanket/slat sandwich, you might not get the real wood temperature.
So, if possible, I'd like to get a blanket with a sensor inside. I could use it to monitor the temperature, at first, and maybe add a temperature controller in the future if it would help.   I do have a big (1500 watt) dimmer I can use to control the power to the blanket, and a timer.
The only blanket I can find on the web is from LMI. Does anyone know if their blanket has an internal temp sensor?
Any other recommendations as far as who and where to get a blanket (and what to look for?
Thanks for any advice or comments,
Phil
PostPosted: Wed Mar 29, 2006 1:31 am
The latest issue of Guitarmaker (#55 for those of you following along) has detailed instructions, parts lists, etc. for how to build a true temperature control unit.
PostPosted: Wed Mar 29, 2006 1:43 am
John Hall at BluesCreek has blankets. Also Omega Engineering has them but there is often a long wait. None have a temp sensor built in but you can go to Omega with part # CO3-J which is a cement on thermocouple.
The article that Brock talks of is worth the price of membership if you aren't already an ASIA member.
PostPosted: Wed Mar 29, 2006 3:15 am
I use Minco blankets and have been quite happy with their performance. They have fast shipping and have many custom sizes and wattages available.
tim...
PostPosted: Wed Mar 29, 2006 5:29 am
The rheostat works ok, but just to be clear... the thing in the ASIA journal is a TEMPERATURE CONTROL UNIT. You can dial in a temperature and it will maintain that setting.
Very slick.
PostPosted: Wed Mar 29, 2006 10:12 am
   The ASIA control is nice design. The investment in time is worth it. I may have to build them myself. The set up I came up with was affordable and relyable. Wood bending isn't rocket science. If you would like some instructions send me an email tippie@epix.net and you can get a copy
john hall
PostPosted: Thu Mar 30, 2006 1:26 am
To add to what Brock is saying about the ASIA journal unit is that it has a thermocouple and thus a feedback loop where the actual temp is fed back to the unit to let it know when to turn off and back on.
PostPosted: Thu Mar 30, 2006 3:03 am
[QUOTE=Pwoolson] Omega Engineering has them but there is often a long wait. None have a temp sensor built in but you can go to Omega with part # CO3-J which is a cement on thermocouple. [/QUOTE]
Paul is there a companion Omega or other manufacturer temperature controller you'd recommend?
PostPosted: Thu Mar 30, 2006 3:15 am
Watlow also makes controllers and sensors for their blankets that are programmable, so you can set it to heat up to a temperature, hold for given time, and then cool down to another temp and hold for time, at least I'm pretty sure they do that. I imagine they aren't cheap though.
